It is currently Mon Aug 11, 2025 1:06 am
PostPosted: Sat Oct 31, 2009 6:33 pm
First name: Big
Last Name: Jim
I have an idea for a mando and it has some very tight radius points . Has anyone ever cut those from solid block instead of bending ? Is it as solid ? Obviously there are extra joints involved , does that detract from the sound ? Has anyone ever tried this or is this just a bad idea??
PostPosted: Sat Oct 31, 2009 6:57 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I'm pretty curious about your concept, but I am CERTAINLY NOT an expert. Why don't you post a drawing of your concept, and then let the experts chime in? I would like to hear their answers as much as you would.
PostPosted: Sat Oct 31, 2009 6:58 pm
Last Name: Dunn
City: Wurtsboro
State: New York
Zip/Postal Code: 12790
have you ever taken a little more than a blade width off of the end of a board. the thin piece would not be strong and snap with little force. If you cut the same thickness off the side of a board it takes much more force to break. what i am trying to say is you would end up with alot of end grain in some spots and it would split. I think
It is better to try and fail, than never try at all
PostPosted: Sat Oct 31, 2009 7:05 pm
Last Name: Shaw
City: Philadelphia
It would be weaker because the grain lines would be very short on the curves and the grain lines are a weak point in wood. Since the sides on acoustical instruments are so thin it would be very weak compared to bent sides. The Puerto Rican CUATRO is cut from solid block of wood but the sides are very thick compared to most acoustic instruments and the back is all part of the same block. It's basically hollowed out into the instruments shape.
PostPosted: Sat Oct 31, 2009 7:23 pm
First name: Big
Last Name: Jim
I would love to , but every time i try and post pics here it tells me they are to big . and im no computer wizard
PostPosted: Sat Oct 31, 2009 7:44 pm
How tight? Most woods can be bent into pretty tight bends if you thin it enough and you get it nice and hot.
Part of the "scroll" on the F-style mandolin is a solid block. Not so much because it is such a tight bend, but because it is right next to the neck block and the side is terminated and glued to this extision of the neck block.
PostPosted: Sun Nov 01, 2009 6:43 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've never built a Mando, but I've built Violins. The ribs of a Violin are made of several pieces, and several blocks. I don't see why this wouldn't work with a Mandolin.
PostPosted: Sun Nov 01, 2009 7:51 am
First name: Big
Last Name: Jim
here is shape im playing with , not sure if im going to change it any . as you can see im not very much into doing the "normal stuff " laughing6-hehe looking at tail from bottom neck joint at top
PostPosted: Sun Nov 01, 2009 8:53 am
Sure, I've done it many times on my own designs. Here's one where the inside of the top front point is part of the nose block with no rib, and the rear treble point has no rib in the tight radius, but is part of the block.
PostPosted: Sun Nov 01, 2009 10:40 am
First name: Big
Last Name: Jim
very nice , I may sharpen some of my radius points to make it a bit easier .
PostPosted: Sun Nov 01, 2009 1:29 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Cool shape Haans!
http://www.PeakeGuitars.com
PostPosted: Sun Nov 01, 2009 2:26 pm
Wow. Beautiful instrument Haans.
PostPosted: Sun Nov 01, 2009 8:56 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Would this not result in a terrible inefficiency with regards to wood use? Plus, it would seem to me (as others have mentioned) you would expose a lot of end grain.
With that said, I am still interested in what the experts have to say.
PostPosted: Mon Nov 02, 2009 8:42 am
Thanks guys!
Here are the ribs for a couple of my mandolins...as you can see, the blocks are large, and while there is end grain, it ain't goin' no where.
Users browsing this forum: DennisK and 42 guests
